Found grinding noise in H axle
Illinois Farmal
06-29-2006 19:14:24
After closer inspection I found that the grinding noise I was hearing wasn't coming from the axle after all. The nuts on the rim clamps had worked loose and it was actually movement between the wheel and the rim that was making the noise. Tightened them up and no more noise. Thaks to everyone who answered my previous post.
williamf
06-30-2006 03:52:21
 Re: Found grinding noise in H axle in reply to Illinois Farmall, 06-29-2006 19:14:24
A Super M I was looking at before I bough my H, all the rim clamps were loose on one wheel. The owner told me about it before I drove it around. Hadn't gotten around to it. He was using the tractor to pull a mower.
I tightened them for him while I was there. Wish I could have bought that one, too.
Wm
Allan In NE
06-30-2006 04:34:53
 Re: Found grinding noise in H axle in reply to williamf, 06-30-2006 03:52:21
An old neighbor of ours got buried in two pieces because of that.
Tractor threw him along with the rim and then proceded to walk right up his middle with that naked wheel. Sliced him right in two.
Allan
Farm Girl
06-29-2006 21:39:04
I had the same problem only with the front wheel rim. It happened right after we painted the rims, insert and had replaced with new rubber. It felt like the rear end was hitting on the teeth in the gears. But after riding and watching the rotation of the tire the same noise was in the same place on the tire when it was down on the road surface. Found bolts had worked its self loose. Boy was I happy it was not the rear end. Then it worked its way loose again this week. They do not seem to stay tight.
River Bottom Farmer
06-29-2006 19:31:50
Had that happen to me just a while back didnt make any noise just notice it when I was washing my rims down Bet they wont come loose again.I torque them with a torque wrench and also found the other side wasnt as tight as I thought I had them either must have been clamoed unevenly and worked loose under a load...RBF
