Stepped or flat pistons?
Beninarkansas
06-30-2006 13:55:02
Will stepped pistons work in a tractor fuel head? 52 Super C. Do I need to find flat head pistons? The guy at Yesterdays Tractors didn't know. I ask him this while trying to order an engine kit. Thanks.
the tractor vet
06-30-2006 16:44:52
 Re: Stepped or flat pistons? in reply to Beninarkansas, 06-30-2006 13:55:02
The step head will be fine and you could even run a high alt. piston and still have enough clearance .
El Toro
06-30-2006 16:32:28
The Super C's had the C123cid engine that had a sleeve bore of 3.125". You could install an overbore kit without any machining to 3.250" bore. You can probably install the stepped head pistons if the head hasn't been milled a lot. If it has the valves may not have enough clearance
to clear the pistons. Hal
Tom Widnsor
06-30-2006 15:14:14
You must be careful with your thinking and measuring. The gas engine I have has 3 7/16 pistons. The other ones I have have 3 3/8 pistons.
Never had aproblem
06-30-2006 15:05:51
i haven't had a problem with running step heads in my A or B and they both hae different heads.
