piston diminsions
bland
07-10-2006 06:29:38
lost my book, need to know how big the pistons on my '52 cub are so i can find a hone to fit can anyone help me
thanks
ryan
Janicholson
07-10-2006 06:47:51
 Re: piston diminsions in reply to bland, 07-10-2006 06:29:38
Ryan the book will be no help, nor will telling you do any good. The individual sizes of the pistons in one batch need to be measured. The bore needs to be honed to accommodate that piston alone. Sunnen brand straight hones are the answer. (or similar high quality parallel stone hone. Following the guidance of the hone instructions, and putting hatchmarks on the cylinder of an angle between 40 and 50 degrees, by proper stroking speed is essential. A good micrometer and measuring techniques is mandatory, as is a bore mic, and technique for its use. Feeler gauge techniques can also be used with success. JimN
El Toro
07-10-2006 06:38:07
The piston diameter is 2.625" provided the block hasn't been bored oversize. I think you should take the block to an auto machine shop. They have all the micrometers for accurate machining
and the expertise. Hal
