Farmall H hard to start when hot
Guyzoo
07-17-2006 18:39:37
Hi, my farmall H is really hard to start when the engine is hot. Can it be the spark plugs??
The engine has been rebuilt along with the distributor and the carb last year but I didn't have had any problems with it since two days ago when I was moving with the 7ft sickle bar mower.
Once it is started it runs like a kitten with no smoke. Any advices would be really appreciated!!
Once Again THANKS!!!!!
Cedric
07-18-2006 02:33:32
 Re: Farmall H hard to start when hot in reply to Guyzoo, 07-17-2006 18:39:37
Check out both the condenser and the coil.
Sid.
old
07-17-2006 19:19:07
Check the spark when its hot and will not start. If its a poor yellow spark you coil might be going bad.
Guyzoo
07-17-2006 18:46:51
Oups, I forgot to said that the compression is about 140-150 on all cylinders and it usually starts real fast, even in the winter. It is almost started before you toutch the button. LOL
Sorry for the second post.
