M piston wont come
Jd's sound like
07-27-2006 13:11:26
Im overhauling my 1950 farmall M and the frthrest piston back wont come up i hammered the part that goes around the crank and got it off then i pushed it up and it would not come it acts like the sleve at the top is smaller then the rest of the sleve nothings hitting dow bottom
Janicholson
07-27-2006 17:04:22
 Re: M piston wont come in reply to Jd's sound like cork guns, 07-27-2006 13:11:26
The answers below are good. (except the one that does not make sense to the topic) The rings grooves in the cylinder #4 are also carboned up to the point that the rings cannot collapse inward enough to get past the ridge they speak of. Push the piston back down to ridge ream. JimN
Roger Lubiens
07-27-2006 14:33:15
 IHC Deep Freeze in reply to Jd's sound like cork guns, 07-27-2006 13:11:26
We have a model 111 deep freeze in our basement that runs. It was purchased used in 1957 and keeps on running. Any idea when and where this model was made?
Buzzman72
07-27-2006 20:17:59
 Re: IHC Deep Freeze in reply to Roger Lubiens, 07-27-2006 14:33:15
Probably built at the IH refrigeration plant in Evansville, IN...the plant that was converted to produce M1 Garands during WWII.
That plant's been Whirlpool for a lot of years now.
RustyFarmall
07-27-2006 13:25:29
You are encountering what is called "ring ridge". As the piston and rings move up and down in the sleeve, the sleeve wears out, except for a small portion at the top because the piston never gets that far up. You may need to use a "ridge reamer" to cut that ridge away, or just push a little harder. You run the risk of breaking some of the rings, and possibly damaging the piston, but if you are replacing the pistons and rings anyhow, it doesn't matter.
old
07-27-2006 14:00:45
 Re: M piston wont come in reply to RustyFarmall, 07-27-2006 13:25:29
I think you where typeing at the same time I was I just got my post in a nano second before you did LOL
old
07-27-2006 13:22:33
Did you use a ridge reamer on the sleeve/cylinder before tring to pull the piston?? If you didn't then that where your problem is. Slleve/cylinder wear and the rings leave what is called a ridge at the top, most of the time its about a 1/4 or so tall and if the ridge isn't removed you will have problems pulling the picton and whats worse if you use the same sleeves you can brake rings when you put the picton back in
