H and Super H transmission gears
r4etierd
07-30-2006 16:56:12
I recently took a Behlen 9 speed from a !948 H Will it work in a 53 Super.If my memory is correct the constant mesh gear in a super is a little wider than one in an H, I am more concerned about the OD of the transmission bearings, don't know if there the same or not. My CIH parts disc doesn't cover Super H.I'm thinking if I use all the H gears and shafts it might work
Dave Slater
07-31-2006 06:34:54
 Re: H and Super H transmission gears in reply to r4etierd, 07-30-2006 16:56:12
Yes, use all H gears including reverse idler gear.
Steven@AZ
07-30-2006 20:59:20
I know that the Super H had wider gears and they were also hardened differently... I believe the teeth count was also different as the Super H had for sure a faster 4th gear and possibly the others as well.
Dr.EVIL
08-01-2006 09:04:21
 Re: H and Super H transmission gears in reply to Steven@AZ, 07-30-2006 20:59:20
And the big thing was the pilot bearing between the input shaft & the sliding gear shaft was much bigger on the Super H.
