Does anyone know the weight of a farmall W6 ?
joey from ma
08-13-2006 08:35:38
I bought a W6 to pull with but I'm not sure of the weight. I looked on the Tisco web site but the infomation doesnt seem right. They say it weighs 5500 lbs and a farmall M weighs 6600 lbs which doesn't seem right because the W6 has more cast iron on it than a farmall M. Any help would be greatly apreciated.
joey from ma
08-13-2006 18:36:18
 Re: Does anyone know the weight of a farmall W6 ? in reply to joey from ma, 08-13-2006 08:35:38
I'm actually tring to get it to weigh 7500lbs for the pulls next weekend. Thanks for your help.
RustyFarmall
08-13-2006 09:31:45
An M will not weigh 6600# without adding a lot of weight, in fact, as shipped from the factory an M would weigh closer to 5,000# or less. The W6 might be close to 5,500#, but I think it will weigh less.
CNKS
08-13-2006 09:12:05
Take it to your local Co-op and weigh it, or a truck stop that weighs trucks, or if your pulling place has scales, there. That's the only way you will ever know. Easy to get them up to 5500, though.
champspa
08-13-2006 08:55:22
shipping weight according to I H data by Guy Fay is 4830
KRUSS
08-13-2006 12:40:40
 Re: Does anyone know the weight of a farmall W6 ? in reply to champspa, 08-13-2006 08:55:22
I'm normally not much of a tractor pull fan, but I own both an M and a W6. Both run well and look not so good. Often wondered which would out pull which. When the bouncing a jumping started I would prefer to be on the W6. I'll likely get kicked off this forum for saying so, but all things considered I prefer the W6 as a tractor unless agility is a factor. Pretty hard to fault either one.
