Farmall Serial # tag
Russell S.
08-23-2006 06:52:04
Can anyone tell me how to remove the rivets from an old serial tag from a Farmall 200 and how to install a new one? The tag is badly beaten and eroded away and I want my restoration to be complete. Thanks for your help.
Peabody
08-23-2006 11:21:41
 Re: Farmall Serial # tag in reply to Russell S., 08-23-2006 06:52:04
If you purchase a replacement plate from OEM Tractor Parts, it comes with new rivets. Just drill the old ones out.
El Toro
08-23-2006 07:27:40
You can drill out the old rivets and use pop rivets to reinstall the new tag. Hal
kfox
08-23-2006 09:48:24
 Re: Farmall Serial # tag in reply to El Toro, 08-23-2006 07:27:40
I used a pair of wire cutters and got a good bite on the head of the rivet as close to th tag as I could. Then used a big screwdriver as a fulcrum under the wirecutters and pried the rivit out. It wasn't easy because one of the rivets had been bent when it was installed - due to a big goober in the casting, close to the hole for the rivet.
ken
