Grind in transmission
granger
08-31-2006 11:39:21
I have a pull-behind bush hog that operates off of the PTO of my 51 M. When I make sharp turns (either way)with the tractor to turn around, the transmission makes a horrible grinding noise from the transmission. Can anyone tell what would be causing this?
NDS
08-31-2006 16:39:12
 Re: Grind in transmission in reply to granger, 08-31-2006 11:39:21
I agree noise is caused by U joints but they also can cause gears in transmission to rattle because of jerking or pulsating motion in joints. In extreme cases you can feel it in your feet.
Nat 2
08-31-2006 12:34:33
Rusty's right. It's almost certainly not coming from your transmission. It's coming from the universal joints.
RustyFarmall
08-31-2006 11:48:14
You are turning too short, and putting the u-joints in the power shaft to the brush hog in a bind. You need to make wider turns, and if you have to turn short, stop the pto first.
