Rewiring a Super A
Nickc711
09-03-2006 16:35:50
All the wires currently have been replaced with new wire or is in severe need of new wire.. the green from the copper is showing through..I was wondering what gauge(s) of wire i should use..I found the website Link what colors were use and where..
Jossette
09-03-2006 18:46:35
 Re: Rewiring a Super A in reply to Nickc711, 09-03-2006 16:35:50
third party image
an A diagram
Vacherie
09-03-2006 18:55:06
 Re: Rewiring a Super A in reply to Jossette, 09-03-2006 18:46:35
This is not very clear to me. Does it give gauges and colors?
Jossette
09-03-2006 19:14:30
 Re: Rewiring a Super A in reply to Vacherie, 09-03-2006 18:55:06
colors do not mater.
print it off and use colored markers that are the same as your wires and go from there. The only gauge you need is an ammeter for electrical.
Vacherie
09-03-2006 19:28:17
 Re: Rewiring a Super A in reply to Jossette, 09-03-2006 19:14:30
Colors do matter to some people that are trying to get their tractor back to original. If colors don't matter would you paint your Farmall green and blue and put a sticker or sign saying it was red?
Jossette
09-03-2006 19:54:54
 Re: Rewiring a Super A in reply to Vacherie, 09-03-2006 19:28:17
I guess I would have to say yes. I had an old blue chevy truck we painted red and put all the stickers and plates to say it was 560 wheatland. Pulled like an old plow horse.
CNKS
09-03-2006 19:41:32
That's sort of an apple and orange statement -- The Operators manual does not give colors of all the wires, but you should be able to see what they are if it is the original harness. Aftermarket and probably OEM Case-IH harnesses (I have purchased only aftermarket) come with a printed guide telling the color codes. The aftermarket ones will have different colors anyway.
CNKS
09-03-2006 17:06:35
See the link. You can make it yourself or you can still buy the original wiring. There are excellent diagrams in the Operator's Manual, including diagrams of the exact routing.
SuperA-Tx
09-03-2006 16:50:04
Robert (dont know his name here) has most of the wiring diagrams.
Thrid row, third from left, is like my Super A is wired, its been converted to 12 volt.
If yours is still 6 volt then it will differant. Jossette posted one a few days ago for someone that had the wiring diagram before conversion.
SuperA-Tx
09-03-2006 17:17:53
 Re: Rewiring a Super A in reply to SuperA-Tx, 09-03-2006 16:50:04
Hum, my link didnt work but I see CNKS has posted the link.
Below link will take you to the post by Jossette but I dont see the wire sizes.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=farmall&th=569936
Nickc711
09-03-2006 18:34:32
 Re: Rewiring a Super A in reply to SuperA-Tx, 09-03-2006 17:17:53
ya i have a parts manual which has a diagram but what guages and what colors?????
Jossette
09-03-2006 19:05:27
 Re: Rewiring a Super A in reply to Nickc711, 09-03-2006 18:34:32
the only gauge you need is an ammeter for electrical. water and oil are mechanical units
As far as colors It doesn't mater. operators choice
Red = hot
Black = neg
White = gen
Green = lights
Vacherie
09-03-2006 19:34:14
 Re: Rewiring a Super A in reply to Jossette, 09-03-2006 19:05:27
By gauge he is talking about wire size not ammeter.
Jossette
09-03-2006 20:03:02
 Re: Rewiring a Super A in reply to Vacherie, 09-03-2006 19:34:14
8 and 10 were common even saw 6 on one a while back. what and how much voltage you want to go through there is up to the operator. The bigger the better on them old 6 volts
Nickc711
09-04-2006 16:58:20
 Re: Rewiring a Super A in reply to Jossette, 09-03-2006 20:03:02
what i mean by color was what color theyu come from the factory
