IHC 1456 vibration
GaryD
09-17-2006 17:53:42
I have a 1456 that has developed a nasty vibration close to max. RPM. Anyone have any ideas what's going wrong.
the tractor vet
09-17-2006 18:13:44
 Re: IHC 1456 vibration in reply to GaryD, 09-17-2006 17:53:42
Two things come to mind here (1) the Ft. damper has slipped and that is the first place i would go (2) the clutch is getting ready to come unglued. If the Ft. damper is realy oily it softens up the rubber between the outer damper ring and the inner hub or sometimes with age they just move and set up a vibration that sometimes will shake the filling out of your teeth . If left go it can break the crank. When i install a new damper i put two center punch marks on it , one on the hub and stright across from that one on the outer ring is a nother punch mark that was you can see if it moved.
