M temp gauge ?
Granger
09-23-2006 20:28:47
The last few times I have been operating my 51 M, I have noticed that the temperature gauge only gets up to 110 degrees. This is even after it has ran for an hour. Any ideas on why I am not getting a normal reading & what should I check?
Dr.EVIL
09-25-2006 09:19:38
 Re: M temp gauge ? in reply to Granger, 09-23-2006 20:28:47
I just installed a new temp gauge on Dad's old '51 M two weeks ago. I was surprised the cooling system held EIGHT gallons. It takes a while to get those old Girls warmed up.
riverbend
09-24-2006 06:26:26
It does not sound like there is anything wrong.
I have an H that has to be hooked to the disk and run wide open for ten minutes before the needle gets into the 'run' range.
Greg
Doug75
09-24-2006 05:04:58
I've just had the same problem.I put in a new reproduction gauge in and I ran it for about a hour,it came up a little but it does work.My father who bought a M new in 1950 says that you really have to work the tractor not just run it too get the temp up.
JayWalt
09-24-2006 04:17:06
Min does the same thing. I asm replacing it with an old capillary type one I have here NIP to eliminatre any worries about the gauge being messed up. I plan to change the thermostat this winter, anyone know what kind of thermo a 300u c169 takes?
Granger
09-23-2006 23:02:20
I am going to try to put cardboard around the radiator tomorrow & run it to see if I can get the temp to risel
City-Boy McCoy
09-24-2006 03:57:50
 Re: M temp gauge ? in reply to Granger, 09-23-2006 23:02:20
Be careful when doing that; if it is your gauge which has gone bad, you can cook your engine. mike
Will Sickw
09-23-2006 22:26:41
It is probably the thermostat. Take the radiator cap off right after you start it and see what kind of circulation you have. If the thermostat is open you will see circulating water/antifreeze. If the thermostat is closed,as it should be with a cold engine there will be little motion.
