Thanks Nebraska Cowman!
chadd
09-25-2006 07:23:08
Thanks for your help with the Hydraulic Valve on our M. Tried it out on Saturday. Works like a charm. The reason it wouldn't work properly is that the spring and the piston were rusted tight inside of the valve spool. After I took out the spring clip and tapped on the little piston with a hammer and punch, the spring loosened up and shot the piston to the ceiling. Someone even retrofitted the main belly pump lever lock onto our 1940, so you can just operate the two way lever and not have to hold both. Thanks again for your help,
Chad
Nebraska Cowman
09-25-2006 07:40:58
 Re: Thanks Nebraska Cowman! in reply to chadd, 09-25-2006 07:23:08
Glad to know you got it going.
