130 Oil Filter Cannister - Again...
chad504
10-08-2006 13:42:27
Well I got the gasket sealed with permatex and solme jb weld putty. Now I noticed the copper washer on top, between the bolt and cannister is split. I need to replace it. Does anyone have aprt number or guidance as to what might make it seal?
MN Scott
10-08-2006 20:35:17
 Re: 130 Oil Filter Cannister - Again... in reply to chad504, 10-08-2006 13:42:27
Do what the Cowman says or if you want to look it up go to the online Case IH parts books on the site below. Just click on "Launch Case Ih Parts Catalogs" in the middle of the page.
Nebraska Cowman
10-08-2006 14:54:04
I bet any good auto parts store could fix you up. Oil pan drain plugs use a similar metal gasket.
chad504
10-08-2006 17:51:54
 Re: 130 Oil Filter Cannister - Again... in reply to Nebraska Cowman, 10-08-2006 14:54:04
What diameter (ID) do I need?
Nebraska Cowman
10-08-2006 18:06:15
 Re: 130 Oil Filter Cannister - Again... in reply to chad504, 10-08-2006 17:51:54
On a 130? I don't know, I suppose about 3/4 but why don't you take the bolt with you? You're gonna have to take it loose anyway.
chad504
10-08-2006 18:36:12
 Re: 130 Oil Filter Cannister - Again... in reply to Nebraska Cowman, 10-08-2006 18:06:15
I'm already at work, just wanted to try to get it on the way home.
chad504
10-09-2006 12:18:38
 Re: 130 Oil Filter Cannister - Again... in reply to chad504, 10-08-2006 18:36:12
Well I stopped and got a 3/4", it was a little sloppy, but it seals. The IH dealer did not have it, the next closest one is 60 miles away. Same dealer, but they did but their parts drive was on vacation this week. So it would be a week before my store would get it, or I could drive up and get it. Yeah right. Napa guy and I made a quick guess.
Thanks again!!!!
