Voltage/Current drain...
Russ Lowry
10-19-2006 15:51:06
Hello again, I asked the question last night about the current drain on my Super C. I tested it as one reader recommended, yes I am showing 12+ volts on the multimeter plus.....the alternator is extremely hot to the touch after running the tractor for 5 minutes or so. Would this indicate bad diodes in the alternator? Or....improper wiring job?? Thanks again, Russ
Russ Lowry
10-20-2006 09:52:10
 Re: Voltage/Current drain... in reply to Russ Lowry, 10-19-2006 15:51:06
Morning guys, Let me tell you where I'm at right now.....I noticed this morning that with the alternator connected I am getting about a 3 amp draw on my ammeter. I disconnected the alternator and the ammeter went to zero (middle). I left the alternator disconneced and proceded to put a full charge in the battery (new Battery). I have a tractor show tomorrow in Cullman Alabama and I am gonna take it with the alternator disconnected and with a fully charged battery. It seems to run just fine with no connection to the alternator. Next week I will give the alternator to a lady in the area that repairs them and see if that's the problem. I am thinking that it is! You guys are human enclyclopedias!!!! Keep up the good work!!! thanks again, Russ
Janicholson
10-20-2006 10:06:31
 Re: Voltage/Current drain... in reply to Russ Lowry, 10-20-2006 09:52:10
Good. That tractor will operate for several days on one charge if it isn't started repeatedly. If you can, charge it over night between uses. JimN
Janicholson
10-19-2006 19:15:13
A bad diode in the alt. will do that. Disconnect the alternator and see if the 12+ volts goes away. If it does replace the alternator. So far a good diagnosis, JimN
hhmm?
10-19-2006 21:21:02
 Re: Voltage/Current drain... in reply to Janicholson, 10-19-2006 19:15:13
I don't understand your reasoning,if you disconnect the alternator, the battery is still connected so how can the 12 volts go away?
Janicholson
10-20-2006 06:12:35
 Re: Voltage/Current drain... in reply to hhmm?, 10-19-2006 21:21:02
Sorry, the post was in reference to the earlier dialog and analysis procedure. I had indicated that if one battery post (in this case the pos) was disconnected, and a volt meter was placed between the removed terminal, and the bat post, that there would be a 12+ volt reading on the meter with everything shut off if there was a battery drain. The disconnection of the alternator (which I believe is faulty) would result in that indicated 12+volts to go to at or near zero. Give the other post a look see and I think it will be understandable. Sorry for an incomplete post out of context. JimN
hhmm? again
10-20-2006 20:49:55
 Re: Voltage/Current drain... in reply to Janicholson, 10-20-2006 06:12:35
I now understand. I did see the other message but wasn't sure they were related. Thanks.
IH2444
10-19-2006 17:56:40
Not sure with the limited info you provided. I would suspect the alternator, or a shorted battery.
I would disconnect the basttery and see if it goes down by about 2 volts overnight, if so it has a shorted cell. Replace the battery.
