45 A generator
JDMithcell
10-28-2006 09:59:08
I have a 45A which was missing the generator when I got it I bought a new one and get sparks when I try to hook it up. Should they have a voltage reg. or what am I doing wrong? Do they need to be polerized? Thank's for any help, Mitch
Bob M
10-28-2006 10:18:17
 Re: 45 A generator in reply to JDMithcell, 10-28-2006 09:59:08
You MUST have either a cutout or voltage regulator installed and wired with the generator. Otherwise you will kill both the battery and generator!
Polarization is recommended after you get everything hooked up. Simply jumper the BAT and ARM connections at the cutout or regulator for an instant and polarization will be complete.
