How's the oil get there???
C.S.F.
11-02-2006 16:48:46
Now with my "H" transmission cover back on, after re-filling with new oil.... got to wondering how the oil in the transmission and rear-end levels out, or moves between the two compartments. It looks like the filler hole sits right over top of the divider wall; does this ensure equal amount of oil on both sides?? Seems the level is not up to the inspection plug. Just wonderin" Thanks.
williamf
11-03-2006 09:37:36
 Re: How's the oil get there??? in reply to C.S.F., 11-02-2006 16:48:46
And to help it move around, there are channels built into the transmission housing that slope to the back; when the gears sling oil up the sides it flows back to the rear end. Wm
kfox
11-02-2006 17:15:41
There are holes in the casting between the front & rear compartments. ken
Wardner
11-02-2006 17:08:45
I thought there was a hole in the wall. Maybe I am confusing that hole with the hole on a TA equipped tractor. But no matter. Oil can pass through the ball bearing on the countershaft. The oil level is probably not high enough to pass through the mainshaft bearing.
