Crack In My Carb
Farmer Ryan fro
11-22-2006 15:30:27
On my H there is crack in the carb. How would I fix it? Would JB Weld work? Thanks
RustyFarmall
11-23-2006 05:53:50
 Re: Crack In My Carb in reply to Farmer Ryan from WI, 11-22-2006 15:30:27
Let me guess, the crack is in the area of the load adjustment screw? I've got a couple of H carbs in the same condition, I removed any useable parts, and tossed the rest into the scrap bin. I've got some rebuilt H carbs if you want to go that way.
504-1
11-22-2006 21:01:22
Cracked at the gas line? Over tighten the line?( do not ask how I know) Gas tank repair kit worked great for me (auto parts store)I used a thread from the mat in the kit and wraped it around the fitting and used the glue on it. Good luck!
old
11-22-2006 17:39:30
JB water weld might fix it. DON'T try to weld it up it warps the carb and causes problems with the float. Or you could also repale the carb, I might even have one I would sell
