explain this one?
jcarter
11-23-2006 18:59:25
I had a quick look at a W-9 this morning.Can't remember seeing a gas 9 before. It had a mag. and was steel spokes on the rear with rims welded to them. Front axle was tire type.What I saw that I can't figure out, was a mecanical fuel pump with a glass bowl on the left side of the engine.It was not hooked up to the fuel lines at all.It all looked origional, but it doesn't make sense to me ?Anybody got any ideas? Jim.
mtdan
11-26-2006 12:51:57
 Re: explain this one? in reply to jcarter, 11-23-2006 18:59:25
I have a 1946 W9 serial # WCB17807 has the same fuel pump on it!!
P Backus
11-23-2006 19:25:44
It was likely that the motor was replaced with one from a U-9 power unit, or possibly a T-9 crawler, either of which may have had a fuel pump. If you look at any 9 series block (at least those I"m aware of), the boss is cast into the block for the fuel pump, but the holes not machined for it (unless it was a power unit!)
The cut-down steel rear wheels are more unusual to me.
Paul
Chad Franke
01-02-2007 11:47:50
 Re: explain this one? in reply to P Backus, 11-23-2006 19:25:44
I don't know, I've got 3 W9's, one has the fuel pump, the other 2 have a homemade plate covering the hole. I would guess they all had them, but since they weren't really needed, they were either removed, or just unhooked when they failed...
jcarter
11-23-2006 21:26:31
Thanks.A power unit would be rare around here, but it could have had the motor replaced from a t-9, but haven't seen one of them before either. we have a TD-9.This will be an early W-9, and may have come with steel wheels because of rubber shortage in WW-2. Jim.
