farmall m tractor
Larry Sumner
11-24-2006 12:48:32
i have a farmall m tractor i belive it to be 1947 serial3 # fbk 139140xl can anyone tell me if this is a 1947 or what year. thanks
Randy as in Randy-IA
11-26-2006 14:53:47
 Re: farmall m tractor in reply to Larry Sumner, 11-24-2006 12:48:32
I don't know if you will see this post but '47's all had '47 in the casting codes on the tractor instead of a letter code . Look between your feet on the top cover and on the right side of the main case it will show you the D/M/Y that the part was cast . "47's to my knowledge are the only year this was done .
Don L C
11-24-2006 15:37:00
1947 started with #122823 ----1948 started with #151708.....your #139140 falls in the middle of the '47 year.....
Geoff NY
11-24-2006 13:06:47
1947 looks right. The list is a link you can follow on the left. Under Reserch and Info just click Serial Numbers and go to Farmalls. Geoff
