Farmall Mdl A 1947 plow attach
Angie O.
11-24-2006 20:20:40
Ok, this is a newbie question, again. We purchased the above tractor a couple of months ago and are now getting serious about getting some attachments. Can someone tell me what conversion kit we need to buy to be able to attached a scraper blade to it? Oh, and what size blade, etc. for dirt? We need to be able get this set up before our big snow hits this season (and maybe I'm being to optomistic). But we don't want just a snow blade, we need to be able to move a little earth with it later on too. Thanks so much. Angie
NDS
11-25-2006 06:20:25
 Re: Farmall Mdl A 1947 plow attach in reply to Angie O., 11-24-2006 20:20:40
The simplest and most commom scraper blade is the 3 point hitch rear mount. Finding blade that will fit tractor without 3 point will not be easy. Saginaw makes the best 3 point hitch (in my opinion) and they are $675 plus shipping you can check them out at SaginawCountyTractor.com. 6 foot blade would be good match and they can be found at most any farm supply or tractor dealer.
NDS OOPS
11-25-2006 06:45:38
 Re: Farmall Mdl A 1947 plow attach in reply to NDS, 11-25-2006 06:20:25
Forget everthing I posted. When I saw MDL I thought M diesel do not get the A part.
Angie
11-24-2006 21:02:25
Ok, do we even need a conversion kit? Are there blades made specifically for this model?
Satsop
11-25-2006 07:43:06
 Re: Farmall Mdl A 1947 plow attach in reply to Angie, 11-24-2006 21:02:25
There is a fellow near me that has a super a with blade for sale. He would probably seperate them if shipping wouldn"t eat you up.
gene bender
11-25-2006 15:41:51
 Re: Farmall Mdl A 1947 plow attach in reply to Satsop , 11-25-2006 07:43:06
SUPER A has rockshaft to lift the A doesent.
gene bender
11-25-2006 03:03:16
the plow should come with all the brackets lift lever so forth. Your best move would be to buy the owners manual for the vlade then you will know when you find one if all the parts are there lots of people have bought attments then found out later missing parts.
