pump leakage
Rusty Zerk
11-27-2006 12:35:47
Have a mid-50's IHC 300U pumping hydraulic fluid into the crankcase. Anyone know where I could get a pump rebuild kit or (heaven forbid)have some else rebuild it.Thank's!
simo
12-04-2006 08:47:21
 Re: pump leakage in reply to Rusty Zerk, 11-27-2006 12:35:47
YOU MAY WANT TO LOOK AT YOUR PRESSURE RELIEF VALVE TO BE SURE IT IS FUNCTIONING IF THE CRANKCASE FILLS UP FAST. THIS MAY BE BLOWING THE SEALS IN YOUR PUMP.
RustyFarmall
11-27-2006 12:51:06
Your local Case-IH dealer will have all of the parts needed to rebuild it, but, the pump may be worn enough that a new seal may not completely seal it up, and then you will be taking it to someone for a rebuild.
