140 Question
David Mitchell
12-13-2006 06:38:50
would the grille and assembly be basically the same on a 140 and 240? Any input appreciated
Mark Peters
12-13-2006 16:53:36
 Re: 140 Question in reply to David Mitchell, 12-13-2006 06:38:50
There`s no common parts to the grill assembly or even the grill itself. I have both a 140 and 240.Mark
farmallhal
12-13-2006 15:43:41
David, I have a parts catalog for the 140 with a print/revision date of Sept. 1964. There are two different ones listed in my catalog. One is 372060R91 as noted for s/n's 501 to 23300. The part no. for s/n 23300 and higher is 384913R91. These part no's are for the metal piece on the front of the tractor with the radiator neck cutout. There might be more part no's for tractors following the print date of my catalog as I'm not a 140 expert and I don't have access to any 240 information for you. Hope this is of some help to you. Hal
Hugh MacKay
12-13-2006 15:12:27
David: I've been watching this, don't have your answer. I suspect most folks here don't have both tractors or parts numbers for both. I expect you may have to call for sheet metal parts numbers on both tractors. Someone must have it, and just maybe a bit of activity will generate more activity. At least we hope it will.
