polarity on coil
deene
12-29-2006 19:12:06
am putting a 1950 demonstrator c back to original with 6 volt positive ground what terminal on the coil gets the hot wire and then the other would naturally go to the dist ..thanks
deene
12-29-2006 19:30:06
 Re: polarity on coil in reply to deene, 12-29-2006 19:12:06
thanks guys hope to get it running for the new yr
Bob M
12-29-2006 19:23:52
The coil "-" terminal gets the hot wire from the ignition switch. The coil "+" then gets connected to the distributor.
JayWalt
12-29-2006 19:23:16
Generally speaking, whatever terminal on the battery that does NOT go to ground, is what the hot wire goes to on the coil. Most older tractors are positive ground, so the hot wire goes to the neg of the coil. Hope this helps. In addition, the wire coming from the distributor gets grounded by the points, so that needs to go to the side of the coil which the tractor's battery terminal is grounded to.
old
12-29-2006 19:22:56
This is true all the time. If its + ground then + goes to the distubutor. If - ground then the - goes to the distubutor. That holds true on every coil
