1943 H Farmall Crankcase Breather
Andy Motteberg
01-06-2007 18:52:11
Where can I buy a new crankcase breather for my H Farmall? It goes in the push rod chamber. Thanks.
Tom Windsor
01-06-2007 21:42:52
 Re: 1943 H Farmall Crankcase Breather in reply to Andy Motteberg, 01-06-2007 18:52:11
I am confused with the SS Scratch pad?!?
When you refer to the Breather, are you referring to the pipe that is inside the lifter cover with the holes in it?--that fastens up front and in the rear of the head...where the fumes are sucked out into the air breather on one end, the Carb on the other???
kfox
01-06-2007 22:31:36
 Re: 1943 H Farmall Crankcase Breather in reply to Tom Windsor, 01-06-2007 21:42:52
third party image
Its the cover on the side of the block that covers the valve lifters. It has the pipe that extends down the outside of the engine. The filters are brass mesh, but no longer available.
ken
PS, I found a photo
Andy Motteberg
01-07-2007 09:34:26
 Re: 1943 H Farmall Crankcase Breather in reply to kfox, 01-06-2007 22:31:36
Ok, if they are no longer available, would something like a screen lint trap work like they put in dryers? Thanks. Andy.
Andy Motteberg
01-06-2007 21:48:38
The breather is in the push rod chamber on the mag side of the engine and is inside the cover. Where can I get a new element?
kfox
01-06-2007 19:19:32
I used a stainless steel scratch pad, Brawny I think was the brand. Perfect fit. ken
