HyTran/Mystik Compatability
Michael Sheik
01-09-2007 08:26:31
I run HyTran in my 1066. I purchased a Hesston 1014+2 HydraSwing swather last weekend that I will use behind the 1066. The previous owner said he runs Mystik Universal Trans/Hydraulic fluid in his Ford tractor that he used with the swather. My oil is brand new in the 1066 and do not want to do anything to jeopardize it. Can I hook up to the swather and use realizing there is some mystik in the cylinders and lines on that swather. Probably 2 or 3 gallon estimated. I could drain the hyd. lines but I do not think I can get everything out of the cylinders.
One other question: The side to side swing on the swather has a double acting cylinder(two hoses) but the wheel raise/lower are single acting cylinders thus only one hose on this. Is there a specific port on my 1066 remote coupler on the back that I plug in the single hose or am I going to have to add on something.
Allan In NE
01-09-2007 09:55:12
 Re: HyTran/Mystik Compatability in reply to Michael Sheik, 01-09-2007 08:26:31
You can use either the upper or lower port to lift your mower, however, if you want it to work "right" with the stick, I.E. 'stick back is up', plug the hose in the upper port.
You'll get grey hair worrying about mixing those oils. Forget it and get on with your day. :>)
Allan
