price of a 350
doc travis
02-13-2007 07:42:37
May I ask how much a tractor is worth on here? I looked in the classified adds, but I only found one to go by. Doc Travis
DOC TRAVIS
02-13-2007 09:56:56
 Re: price of a 350 in reply to doc travis, 02-13-2007 07:42:37
Well I have a RC 350 to sell. It has a complete rebuild on the engine which actually is a c175 engine instead of a c169 engine. TA works. I have stripped it down and repainted, not proffessionally. Hoods are in decent shape but not perfect, ding here and there. Hydraulics work and power steering works. No 3 pt. or fast hitch. Tires are old and weather checked but hold air good. What do you guys think?
Thanks Doc Travis
CNKS
02-13-2007 14:45:28
 Re: price of a 350 in reply to DOC TRAVIS, 02-13-2007 09:56:56
C175 is the correct engine--$1500 minumum, $2500 maximum. In that condition, I would pay closer to $1500. New tires would put it in the $2000 range.
RustyFarmall
02-13-2007 12:04:55
No 3 point, tires are poor, $2,500 or less.
old
02-13-2007 08:05:48
I've seen 350 sell for as low as $200 up to as high as $3500 all depends on how good or bad they are. We picked up a 450 a couple years ago for $300 but it didn't run. It had a loader and back blade on it also. Same tractor now would cost around $4000 but we have since gone through it from front to back and it looks real good
RustyFarmall
02-13-2007 08:05:15
You can ask, and you will get some educated opinions. If you have a specifc tractor in mind, you might want to give us some info as to the general condition. Also, location seems to play a part. Tractors on the East coast generally seem to bring higher dollars than the same tractor here in the midwest. For starters, A Farmall 350 rowcrop that is basically junk would fetch about $500 to $800. On the other end of the scale you could be looking at around $3,000 to $4,000--give or take.
