Does the Super C have O-rings on sleeves
Farrell(Utah)
02-16-2007 17:42:10
I recently acquired a Super C but when I started it the blow-by was immense. There was smoke coming from everyplace it could come out. I took the motor apart and found that the sleeve in #1 was really rusted and corroded severely. However, I did not notice an O-ring on the sleeve when I removed it from the block. Am I hallucinating or did IHC not use O-rings on these wet sleeves? Maybe I didn't look close enough and there may be one still in the block. If there are no O-rings how did they seal? Thanks.
Gary in Utah
02-17-2007 10:56:20
 Re: Does the Super C have O-rings on sleeves in reply to Farrell(Utah), 02-16-2007 17:42:10
Howdy, Farrell. Didn't know there was another Utah guy here with a Super C. E-mail me and tell me where you are, I'm in Hooper (west of Roy).
Janicholson
02-17-2007 06:16:38
Clarification:
The top of the sleeve is sealed by metal to metal fit of the rim of the sleeve into the recess (must be clean). THe bottom (spigot end) is "O" ringed into the block with a substantial "O" ring in a groove in the block. Clean and lube with dish detergent as nted below.
JimN
shoo_giesty
02-17-2007 06:03:49
the o-ring isn't on the sleeve, its in the block,probaly can't see it very well because of the rust and sh^& inside but its there.
El Toro
02-17-2007 04:13:28
You need to clean that block area thoroughly where those sleeve seals are installed in the block before installing the new sleeves and pistons. Use liquid dish detergent on the lip of the sleeve before installing it. That recessed area at the top of the block needs to be cleaned too, so the top of the sleeves can fit
properly. Hal
Marv
02-16-2007 17:51:53
The sleeve does have an O ring. I recently replaced the O rings on my Farmall 230 because I was getting antifreeze in the oil.
504-2
02-16-2007 17:50:55
Yup, there should be O rings on the sleeves.
