farmall m re-starting truble
james in mo
06-24-2007 15:42:28
having truble re-starting my tractor. pulled plugs all of them get spark. normily i would say this is a flooding problem but when i pulled it, it start with first roll-over. a tractor informed freind was watching it and dident have a clue. he said it could posibly be a week spark, but i just replaced the coil.
james
Janicholson
06-24-2007 22:33:00
 Re: farmall m re-starting truble in reply to james in mo, 06-24-2007 15:42:28
I'm ging to add that a starter motor that is dragging (needs bushings) will draw down the voltage and keep it from starting. Also small car sized cables are a suspect. It needs 2-0 cables for reliable starting (it is a miricle cure at times) JimN
jonnny2006
06-24-2007 18:32:26
you need to make sure your getting fuel to. if you got any kind of spark it should fire. I sure like my M. Tonight i was pulling my truck as the bat was dead and i could not find the jumper bumpers. so i pulled it in reach of my battery charger. If you got spark it is gas.
El Toro
06-24-2007 16:50:53
I would replace the condenser too. Was that a new coil? Hal
