Trouble - Wide Front End
Matt Weltz
06-25-2007 10:08:16
A while back I purchased a wide fron end from a guy not too far from where I live. I am restoring a Farmall 300 and he told me tha it would fit. Two days ago, when I was trying to put it on, I found that he was either mistaken, or lied to me. The back support bracket is 2" wider than the frame of my 300. Would this be the bracket for a 400 or something? Would it be easy to find and change or to the correct bracket or should I cut this one off and refab it to work? Also, I could not get the steering plate to bolt up to the shaft on the tractor. The holes do not line up but I though they were the same size on all those sizes of tractors. Any help would be appreciated. Thank you!
Steven@ND
06-25-2007 21:01:39
 Re: Trouble - Wide Front End in reply to Matt Weltz, 06-25-2007 10:08:16
The only parts you need are the rear brace and the steering arm... probably not too expensive.
Check with steelwheelranch.com
jonnny2006
06-25-2007 16:31:23
yup you got the bigger one. sell it and get the right one.
Allan In NE
06-25-2007 12:48:24
YEs,
The bigger tractors of that era were exactly 2" wider than the little guys. Also, the steering boss is not "exactly alike" either.
He either lied to ya or didn't know the difference himself.
Allan
RustyFarmall
06-25-2007 13:15:02
 Re: Trouble - Wide Front End in reply to Allan In NE, 06-25-2007 12:48:24
The narrow front pedastal for a Farmall H through 460 does have a smaller bolt pattern than on the M through 560. That is probably why the steering plate won"t bolt up.
