any one near Ashbey minnesota?
jonnny2006
06-26-2007 21:02:34
Hello i'm up in ashbey minnesota near alexzandria mn. I was wondering if any of you are fimilar with the aera. there is a nice h for sale for 850 but it wont stay running..... I think it is gas but im not sure. It did not stay running long enough for me to drive it in all the gears. I cannot do a compression test as all my tools are 240 miles south! i think im gonna pass. altough he will probally get it as it is strait and has nice steel wheel cut offs. its a 42. Fantastic rubber. needs new brake on the right side and is missing the cover to it. All else is ok. Well im gonna go hop in the jacuzzi!!!!! !!
jonnny2006
06-27-2007 18:24:58
 Re: any one near Ashbey minnesota? in reply to jonnny2006, 06-26-2007 21:02:34
puppy money..... .
Andy Motteberg
06-27-2007 13:03:22
I don't know why it would be a compression problem. Sound like an ignition or carburetor problem. Buy it, put in new plugs and wires, clean the points, clean the carb and put in a new carb kit and see if it will run right, if not, it needs more work.
Question
06-27-2007 09:31:09
It won't stay running and you want to do a compression test???? Possible bad compression certainly isn't the problem.
Look at the Photo ads on this site and see what folks are asking for an H. I think you will see that $850 is a pretty decent price!!!!
What cover is missing??? Or do you mean the hood?
Lawmar
06-27-2007 08:24:20
Did you check the coil? I have had customers that can start their tractor and only keep it running shortly due to a bad coil that heats up right away.
Arf
06-27-2007 03:00:22
I am in Alexandria at work but I have no compression tester handy. I have seen several H's go for $500-$700 the last year or two. They all ran okay but with narrow fronts and fair to poor rubber.
Maybe
06-27-2007 01:25:43
"Well im gonna go hop in the jacuzzi!!!!! !!"
Accident lawsuit money???
hks
06-27-2007 09:56:55
 Re: any one near Ashbey minnesota? in reply to Maybe, 06-27-2007 01:25:43
ZING!!!!!
