f-20 question
Charles Lindsey
07-03-2007 07:43:20
I am trying to pull the engine from a f-20, i have the ring of bolts out of bell housing, the mounting bolts out, the radiator, all linkage, engine will not move forward from bell housing. what have i missed. Thanks,
Charles
Charles Lindsey
07-04-2007 11:10:04
 Re: f-20 question in reply to Charles Lindsey, 07-03-2007 07:43:20
Thanks everybody for the good info. I got it tore down, now does the easy part begin?
JohnG(TX)
07-03-2007 12:53:33
On the F-20/regular engines I have pulled, I removed the clutch cover and flywheel first, then pulled the whole assembly off the tractor. There are only four bolts that hold the engine on the frame rails, two up front on the engine mount, and two on the clutch housing. I really don't try to pull just the engine block by itself. Make sure you get the flywheel off before attempting to remove the bell housing from the engine block. You run the risk of destroying the rear seal retainer if they come apart separately. I have photos of how I did it. Email me and I will send them.
Charles Lindsey
07-03-2007 10:14:07
Thanks Bob I got it. The input shaft was welded to the clutch center with rat stuff. Thanks again
Charles
Bob Kerr
07-03-2007 13:33:49
 Re: f-20 question in reply to Charles Lindsey, 07-03-2007 10:14:07
Those darn rats! I know what you mean, You should have seen inside the clutch housing on my 10-20, Mice and bees used it for homes for years. The thick heavy clutch cover was totally rusted out not to mention trying to get the clutch shaft off of what was left of the clutch disc splines, that took a sledge hammer and half a tank of acytelene. It was truly a mess and I wondered what I got myself into!
Bob Kerr
07-03-2007 08:37:40
There might be a threaded stud somewhere hanging it up. Those are dowlels and are taken out by putting a nut on then and turning the nut, they come right out. There also might be a couple bolts on the inside of the flywheel that go to the block , but not sure on that, worth a check though. Look for 2 holes in the flywheel and turn it and see if a bolt head shows up.
