i'm stumped
james in mo
07-04-2007 16:41:21
tractor wont restart. i'v probly flooded it pretty bad but still it should restart after an hour or so. have spark every where. it could be a fuel problem i just dont know. i had-it up to here with this thing..... sorry just venting but relly what do ya think is wrong.
John M
07-05-2007 03:50:33
 Re: i'm stumped in reply to james in mo, 07-04-2007 16:41:21
Did you fix the wiring that burned? If it was running up until then I would suspect that you didnt wire it back correctly.
Dan(Mass)
07-05-2007 03:44:58
James,
You may have a couple of valves stuck open. Take the valve cover off and take a look. Also make sure the butterfly valve on the carb is free. This is the one up near the manifold. I just had a similar problem and found I had a few valves stuck open.
Bob Kerr
07-04-2007 20:02:12
Like the others have said, pull the plugs out , but if you don't have the socket, try this, turn the gas off and leave it off. Open the throttle wide open and crank for a few times and let it sit for a while, then crank again and let sit. if it fires up then turn the gas back on and see if you have black smoke. More than likely the needle valve is stuck or has a piece of crud in between the seat.
james in mo
07-04-2007 19:09:43
i would take the plugs out but dont have a big enough socket. so i going by the carb.
Andy Motteberg
07-04-2007 17:27:36
Check and see if the needle in the carb is stuck or sticking, that can flood it out. You should also check the plugs and clean the points.
james in mo
07-04-2007 17:24:04
i think it was flooded because gas ran out of the carb.
CNKS
07-04-2007 17:55:56
 Re: i'm stumped in reply to james in mo, 07-04-2007 17:24:04
Gas will run out of all IH carbs if they are over choked when starting. Minimal use of the choke will solve the problem. In warm weather you may not even need the choke -- otherwise do as the others say.
Gary in TX
07-04-2007 17:20:26
Could possibly be the float sticking the carb. letting it flood out. I have had that happen a few times. My 301 Deere will do that every now and then. Usually starts back after awhile or I just let it set overnight. Whack the side of the carb lightly with a small hammer or wrench and run some B-12 through the gas to see if that will help.
Tinker IN TN
07-04-2007 17:14:50
If you really flooded it, the spark plugs could be fouled out. Some plugs made these days, foul out easily. I'd try a fresh set of plugs.
Will Sick
07-04-2007 17:00:32
Take out a plug and see if they are wet with gas which would indicate flooding.If the plugs are dry check to see if you have gas flow to the carburetor.
