Taking radiator off an H
Dalton S.
07-13-2007 15:46:45
I am restoring a 1951 Farmall H. I need to take the radiator off, but I am unsure how to. I see that the steering post goes through the top of the frame that holds it in. Do I need to take the steering post out in order to take the radiator off? Where are the bolts that hold it on? Any advice is greatly appreciated.
Red48M
07-13-2007 16:14:45
 Re: Taking radiator off an H in reply to Dalton S., 07-13-2007 15:46:45
You need to take the steering shaft out. You do this by disconnecting the shaft at the U joint, then removing the plug on the front of the bolster. Then turn the shaft and worm gear out. The radiator is held in place by two bolts that you get to from the bottom of the tractor.
