Does Stage II Have 2-Way Hydraulics? (Tell The Truth!)
City-Boy McCoy
07-24-2007 14:53:12
Howdy, Boys: I thought all stage II Super H's and Super M's had 2-way hydraulics (down pressure), but two different people have told me, that while they have LIVE hydraulics, they do not have down pressure, unless you add a 2-way valve. If true, this would explain why someone has gone to the trouble of adding a Char-Lynn 2-way valve to my stage II SH, I suppose.
What is the "real deal" here? Thanks, as always. mike durhan
CNKS
07-24-2007 14:59:28
 Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!) in reply to City-Boy McCoy, 07-24-2007 14:53:12
Power up, gravity down unless you have the factory remote or an add-on valve. In that respect they are exactly like the dead hydraulics on the stage 1-down. Most modern 3 points do not have down pressure, but merely have some form of depth control, which to me anyway, is more important than down pressure.
City-Boy McCoy
07-24-2007 16:38:50
 Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!) in reply to CNKS, 07-24-2007 14:59:28
Thank you, CNKS. That clears it up for me - once and for all. mike durhan
CNKS
07-24-2007 17:27:15
 Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!) in reply to City-Boy McCoy, 07-24-2007 16:38:50
To clarify my answer above (you already know this). Fast hitch or 3 point weren't available when IH used that valve, so it was for trailing implements, which do have down pressure -- I was thinking about the one way Saginaw 3 point on my Stage 2 Super H, which would probably work better with some type of depth control system. But, my understanding is the down pressure on the Super C fast hitch, etc worked quite well -- I don't have one of those.
City-Boy McCoy
07-24-2007 17:49:11
 Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!) in reply to CNKS, 07-24-2007 17:27:15
CNKS:
Yes, I see what you mean. I am quite used to my Super A's, which are factory set-ups and have down pressure. I suppose this was why I erroneously assumed the stage 2 tractors had down pressure, since both the SA and the stage 2 H had factory live hydraulics. Now I know they are not of the same ilk.
My SH has a Char-Lynn 2-way valve on it, and now I know why. I was going to take it off, but now will leave it on and use it.
Thanks again for your helpful information. I really appreciate you and the other fellows who help so many. mike durhan
georgeky
07-24-2007 16:52:54
Mike, you can also put the valve on the regular H or M and have two way hydraulics on those. It just won't be live, so it still wouldn't work with clutch pushed in.
City-Boy McCoy
07-24-2007 17:10:53
 Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!) in reply to georgeky, 07-24-2007 16:52:54
Hi, George. Yes, I knew that, ol' buddy. What I did not know was that the live hydraulics on a stage II set-up only had one way (up) pressure. I know it now. So... both stage one and stage 2 are the same - except for the business of the clutch pedal deactivating the hydraulics on a stage 1. I got it straight now. mike durhan
tn terry t
07-24-2007 18:49:13
 Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!) in reply to City-Boy McCoy, 07-24-2007 17:10:53
a pump is a pump that is a pump ya have to have a two way valve to reverse the direction of the fluid flow nuther words force piston and rod out force piston and rod back in
City-Boy McCoy
07-25-2007 03:36:23
 Re: Does Stage II Have 2-Way Hydraulics? (Tell The Truth!) in reply to tn terry t, 07-24-2007 18:49:13
I understand that. What I did not know was, since a super A has two way pressure, I thought the stage 2 Super H would have it built in also, as both have IH factory live hydraulics. Now, I know that is not the case with the SH (and SM) tractors. Thanks. mike
