Farmall H Optional Lower 1st gear
FarmallHPuller
08-05-2007 20:25:20
I have heard there is an optional lower 1st gear for the farmall H. Does anyone know if this is true? If so where can you get this? I understand you have to replace both the first and second gear?
Wardner
08-06-2007 19:23:19
 Re: Farmall H Optional Lower 1st gear in reply to FarmallHPuller, 08-05-2007 20:25:20
If the low-low H is built like a M, you will need a new countershaft with integral gear, and three more gears. The kit was sold as a package by IH. It'sll there in the parts book.
The parts are:
countershaft w/gear
second gear on countershaft
first gear on mainshaft
reverse idler gear
DC-PA
08-06-2007 19:01:01
Believe I have a H with slow gears, according to the serial number. I'm willing to sell the entire tractor. It runs good. Let me know if anyone is interested?
FarmallHPuller
08-07-2007 18:42:29
 Re: Farmall H Optional Lower 1st gear in reply to DC-PA, 08-06-2007 19:01:01
Well I am more so looking for just the gears, not the whole tractor. If you would be willing to sell just the gear?
r4etired
08-06-2007 09:27:48
My book indicates X1A low speed gears X19 special transmission X21 7 mph gears,8000'altitude XIE gas,5000'altitude,low speed gears
CNKS
08-06-2007 05:41:28
You will need the sliding gear and the countershaft gear (someone correct my terminology). Likely available only from salvage, unless you can find the tractor; they are not common. The speed of 2nd is not affected. IH only produced a high 4th and a low first, no other gears were affected. Come to think of it, I believe what you want is the low-reverse combination. Look up the part mumbers and diagram at www.caseih.com. That site is somewhat incomplete, but I think it will show that.
FarmallHPuller
08-06-2007 05:31:35
I would have to look at the serial number, but I am pretty sure I have the high 1st gear right now. It goes about 3.3 or so in 1st.
georgeky
08-05-2007 20:35:06
Yes there are low gears for them. We need the serial number suffix to know what you have now. Several different letters can mean low low gear. I don't know for sure, but they could be available new. They will be expensive though. Give Brad a call at 1-888-824-0544 and he can tell if they are available new.
Andy Motteberg
08-05-2007 20:28:24
I have heard of the lower gear in the late H's or super H's. I think the serial no. ends with XJ if it is a slow model, I'm not sure if it is XJ, but I think it is.
earlschieb
08-05-2007 21:44:32
 Re: Farmall H Optional Lower 1st gear in reply to Andy Motteberg, 08-05-2007 20:28:24
Well, I was told that it would be an X1A, in the newer H tractors, I would love to have an H with the Low Low, to go along with my X1F H, which has the high speed gears.
georgeky
08-05-2007 22:21:59
 Re: Farmall H Optional Lower 1st gear in reply to earlschieb, 08-05-2007 21:44:32
That is correct for just the low low gear. Several different letters could mean low low gear with other options. I have an M with X1F on it. It only has a high 4th gear for 7 MPH. The J would be 5000 foot pistons and high gears.
