715 combine
smdv806
08-06-2007 11:01:35
What size diesel motors were available in the 715 combine? Also how do you identify the engines?
steve il
08-06-2007 14:00:42
 Re: 715 combine in reply to MN Scott, 08-06-2007 11:01:35
smdv806 said: (quoted from post at 19:48:53 08/06/07) Is the 301 diesel any good? That isn't one of those junk powercell units like in the 460 is it?
hi, yes this is the same engine as the 4 or 560 had, had to start them with the glowplugs even when it was 90 degrees.this type engine lasted better in the 560 at 70 hp than in the 715 at 95 hp. most throwed number 5 rod after a little age. later 715s had 310 german engine.i think the 310 had the diesel pump next to graintank.
smdv806
08-06-2007 14:20:56
 Re: 715 combine in reply to steve il, 08-06-2007 14:00:42
How many hours can you expect to get out of a german 310 vs a later IH 414 series diesel? Are these 310s fairly decent?
El Toro
08-06-2007 11:43:48
 Re: 715 combine in reply to smdv806, 08-06-2007 11:01:35
If this is the IH 715 I only have the 301 diesel engine listed. Hal
smdv806
08-06-2007 11:48:53
 Re: 715 combine in reply to El Toro, 08-06-2007 11:43:48
El Toro
08-06-2007 11:59:51
 Re: 715 combine in reply to smdv806, 08-06-2007 11:48:53
I never had any of the 301 diesel engines. Some of the men that post on here will probably know. We had a Case combine with a Wiscosin engine and I always liked the sound. Hal
Duane NC OH
08-06-2007 18:33:21
 Re: 715 combine in reply to El Toro, 08-06-2007 11:59:51
our 715 had a 301D. it is the same block as the 282D that 560's had. only difference is the 301 had no sleeves. we never had any motor problems with our 715. after our 560D cracked a block we put in 301D engine from a 715. it was a pretty forward swap. this engine has not given us any trouble either. still have the 560 but the 715 was happily traded on a 1620.
fwiw
Duane
