Replacing M Hydraulic Cylinder ?
FarmAll-or-Nothing
08-26-2007 04:01:19
third party image
Where can I find a replacement Hydraulic Cylinder for a farmall M #31 powerloader?,, It wouldn't have to be original equipment , just be able to fit without doing major modifications .
Or would it be cheaper to repair what I got?
Is there a good manual for repairing these cylinders?
Brownie450
08-26-2007 05:19:02
 Re: Replacing M Hydraulic Cylinder ? in reply to FarmAll-or-Nothing, 08-26-2007 04:01:19
These cylinders are not hard to work with. There are 4 or 5 V-packings in the nose & the brass bushing-- if not available from IH, is a standard size or able to be turned by someone with a lathe. On the lower end, there is a cup leather which usually is bad, & a thin paper gasket to seal both ends to the cylinder tube. The last stuff we got from IH was 10 years ago. Worth a try at IH.
