Farmall H flywheel
Travis Tietjen
08-27-2007 21:10:49
I inheritd an H with a bad flywheel. The tractor runs like a top if you give it a pull but you cannot start it with the starter because the flywheel is all ground off.I belive you have to split the tractor to fix this correct? and if so can anybody tell me from experence the best and easiest way to do this. Thanks, Travis
Owen Aaland
08-28-2007 07:56:02
 Re: Farmall H flywheel in reply to Travis Tietjen, 08-27-2007 21:10:49
Unless the ring gear is really ground off, a new starter drive and dressing the ring gear teeth with a file will get you going for a long time.
Patrick Martin
08-27-2007 21:45:35
Travis Tietjen said: (quoted from post at 21:10:49 08/27/07) I inheritd an H with a bad flywheel. The tractor runs like a top if you give it a pull but you cannot start it with the starter because the flywheel is all ground off.I belive you have to split the tractor to fix this correct? and if so can anybody tell me from experence the best and easiest way to do this. Thanks, Travis
Yep...gotta split it.
