Super C rims
TimWafer
08-28-2007 11:15:28
third party image
Here’s a picture of my “NEW” Super C. The engine was stuck but I got it free this weekend after soaking in ATF and warming it up by running steam from my Steam Jenny through the water jacket. As you can see I’m in need of a couple new front rims & tires. The rims are 6-bolt rims on a 6” circle. Hub looks to be 4-5/8” and they are 15” x 3” rims. This differs from the usual rims I’ve always seen on Super C’s. I think mine is a 54 so that puts it near the end of production. Was the 6-bolt rim an option? They appear to be original to me.
Thanks
Tim
K.B.-826
08-28-2007 11:49:01
 Re: Super C rims in reply to TimWafer, 08-28-2007 11:15:28
You've got the wide front off of a 240 Farmall. The dead give-away is the way the stay rods come all the way back to the clutch housing.
old
08-28-2007 11:43:57
I've always wanted rig up some way to get hot water into one that is stuck but have never figured out a way to do it yet. Doing what you did porbably help a lot as far as getting it unstuck. I know I always tell people to use ATF and the hot water is also a very good trick to use if you just have the stuff to do it
