6 volt battery cables
flashback
08-28-2007 13:05:10
getting ready to install 6 volt battery on my A. Will make it positive ground. There has been some talk about heavy cables. Battery will operate lights and starter only. Recommendations please
Deamer1
08-30-2007 05:59:58
 Re: 6 volt battery cables in reply to flashback, 08-28-2007 13:05:10
I ordered OEM from the local IH dealer. They weren"t too bad in price, and they fit the tractor as they should. Looks good and works good.
Ron in Nebr
08-28-2007 21:44:39
Check out some of your irrigation engine places or over the road truck shops to maybe find the heavy cables.
teddy52food
08-29-2007 07:10:56
 Re: 6 volt battery cables in reply to Ron in Nebr, 08-28-2007 21:44:39
Also the welding shops (suppliers) may have it in bulk.
CNKS
08-28-2007 18:25:19
My Super A has 6 gauge -- it works fine, it does not take much to turn that engine over. The H engine-up is a different story. In my area anything larger has to be ordered, I can't just go down and buy a cable at the local parts place. Of course I never plan ahead, either.
CityBoy-McCoy
08-28-2007 16:46:14
"Double ought; worry not."
Gauger
08-28-2007 16:38:54
Jonh T knows of what he speaks, less voltage more amperage = 00
55 50
08-28-2007 21:15:52
 Re: 6 volt battery cables in reply to Gauger, 08-28-2007 16:38:54
Ah - - - Make that less voltage DROP, more amperage = 00!!!! Or better yet, less voltage DROP IN THE CABLES which means more voltage at the starter.
John T
08-28-2007 16:36:26
I will toss in yet another recommendation and confirmation of that below ALWAYS USE 00 GAUGE BATTERY CABLES ON SIX VOLT SYSTEMS. Youre only starting with 6 volts in the first place and the less voltage drop n heat n energy you waste in the cables the more available at the starter..... ..... PERIOD Its not as important on a lil A or B or Cub etc., but on an H some and ESPECIALY AN M, bigger is definitely better.
John T
El Toro
08-28-2007 13:35:52
I would use the 00 cables. Hal
Harold H
08-28-2007 13:19:11
Six volt system should be positive ground. I would recommend you use 1 gage cables. You can get away with 2 gage but 1 gage are better.
Harold H
rustyfarmall
08-28-2007 13:16:28
Six volt battery cables need to be on #1 guage or even better #0 guage, and if you can find #00, even better.
