Steering shaft bearing
Doug Coutts
08-29-2007 08:51:07
Anyone ever try to take the slop out of the steering shaft center bearing - part #351126R12 on a Super C? I turned the shaft around to get a new spot on it, but the bearing is still sloppy. A new one is close to $100. (or does it even matter?)
Thanks
Doug Coutts
08-30-2007 11:03:08
 Re: Steering shaft bearing in reply to Doug Coutts, 08-29-2007 08:51:07
Thank you Jim, I'll get to work on it.
Doug Coutts
08-30-2007 09:23:49
Thanks for your advice. I'll follow it.
Just to be specific, I am asking about the short horizontal steering shaft, with a split two-piece housing that bolts to the clutch housing (not the one up by the steering wheel). I suppose I could see clamping the two halves of that small housing together in a vise & reaming to accept a bushing, but that shaft has pressed/welded yokes from the factory, and I'd hate to mess with one of those just to slip a bushing on?
Janicholson
08-30-2007 10:52:58
 Re: Steering shaft bearing in reply to Doug Coutts, 08-30-2007 09:23:49
I was thinking of the other shaft. No issue with a split bushing, The bushing needs to be retained in the housing External snaprings on either end would work, a snap ring on one end and a flange constructed on the other when the bushing is turned, or flanges on both ends. JimN
Doug Coutts
08-29-2007 10:34:47
JimN,
Just thought of something. The shaft has welded yokes on either end, no way to slide a bushing over. Is that some kind of a split bushing?
Thanks again
Janicholson
08-29-2007 16:23:19
 Re: Steering shaft bearing in reply to Doug Coutts, 08-29-2007 10:34:47
It could be, however the housing needs to be drilled/reamed for the bushing, thus the shaft needs to be out of it. Replacement yolks that pin to the shaft are available from Motion Industries (with help from the counter person) Then a traditional bushing works, JimN
Doug Coutts
08-29-2007 10:05:50
Thanks Jim, I've got a guy who can do that for me.
Doug
Janicholson
08-29-2007 09:15:21
It matters. A machine shop can bore it out and rebush it for a modest price. (shop it) the bushing should be oil impregnated, and fit to about .002 to .003" clearance, and have a drilling for the grease passage. JimN
