i-4 3point hitch
dennis vanpoper
08-31-2007 19:36:12
i put a homemade3 point hitch on my i-4.i was wondering what the lift on the hitch should be?mine turned out to be 24inches.i put adjustable lift arms on it.is 24inches of lift right?i can change it a little by changing the hole position on the bottom links.plus i put 2 3x8inch cylinders on it.how much is the most i should lift.500lbs or 1000lbs or more?i dont know.thank you
Harold H
09-01-2007 08:59:46
 Re: i-4 3point hitch in reply to dennis vanpopering, 08-31-2007 19:36:12
Dennis,
Do you have a problem with interference of the top link with the seat at full lift? Post a picture of your hitch.
Harold H
dennis vanpopering
09-01-2007 17:41:03
 Re: i-4 3point hitch in reply to Harold H, 09-01-2007 08:59:46
no it does not hit the seat at full lift.but it is close.no i dont have a picture but i am gonna take some pictures soon.i just bought a scanner copier printer.when i figure out how to use it i will post some pictures.thank you
