Super M reservoir oil level
Chris NW Ind
09-10-2007 20:04:18
The manual I have for the Super M covers the early versions and not the later w/ live hydraulics. I'm guessing the fill level is right around the filler elbow. Anybody care to comment?
I'm replacing a leaky hose (which got leakier when I started fiddling with the two-way valve) and dumped most of the fluid out.
Thanks, Chris B.
Thack
09-11-2007 09:37:28
 Re: Super M reservoir oil level in reply to Chris NW Ind, 09-10-2007 20:04:18
My manual says to fill until you can see oil at the bottom of the filler elbow, with the tractor running.
Bob M
09-11-2007 05:26:29
Chris - I don't know what the "correct" fluid level is. But I keep mine filled to just a bit below the filler elbow.
It's worked fine like this for 15+ years.
