f-30 engine
wegman in mn
09-13-2007 16:10:20
will the f-30 engine fit in the f-20 rails? I wanna have power that of a stock f-30 but have the weight of an f-20.
thanks,
Len Rahilly
09-15-2007 15:21:54
 Re: f-30 engine in reply to wegman in mn, 09-13-2007 16:10:20
The F-30 has a 4.25" bore versus 3.75" for F-20. Wouldn't the engine be a good bit longer? I believe the stroke is the same, so I don't know about any differences in engine height.
I'm wondering if the F-20 gearbox can take the extra torque of the F-30 engine?
F-Dean
09-13-2007 18:16:21
You might make it work if you take the rails from the F-30 and bolt them onto the F-20 transmission. However, you will also have to switch the gas tank and steering wheel mount to account for a taller engine. By now you may have lost any weight advantage!
Andy Motteberg
09-13-2007 16:44:54
I don't think it would fit. The F-30 bell housing bolts on with four bolts, and the 20 bolts on with two.
