Question about a water jacket plate
Mike CA
09-16-2007 17:19:21
So I pulled the water jacket plate off my H like I said last week (Broke a bolt and a stud, but drilled and tapped them today with some help from a club member) So today I took a wire brush to the back of the plate where the water channels are to try to knock off some rust. Well, chunks of those channels broke off from being too rusty. So I'm thinking, if I'm going to have to replace it, now would be the time. I saw a new water jacket plate on YT for $55. That's a good chunk of change for me right now. So I'm wondering if I should just deal with what I have, or spend the money now and just set back my progress a little?
Mike CA
09-16-2007 21:09:23
 Re: Question about a water jacket plate in reply to Mike CA, 09-16-2007 17:19:21
Wardner said: See if he has a deal on micrometers.
It doesn't say on the site whether he carrys tools or not. I'll ask. Is this something you need, or I'm going to need? If for me, why will I need it?
D Slater
09-16-2007 19:33:10
Check around and you can find for less than $30.
Mike CA
09-16-2007 19:27:41
I'll call him tomorrow probably. Maybe I can get a 'Mikes of America' discount! third party image
Wardner
09-16-2007 19:43:07
 Re: Question about a water jacket plate in reply to Mike CA, 09-16-2007 19:27:41
Owen Aaland
09-16-2007 18:19:37
Since you are not going to be working this tractor hard this plate is one part that you could reuse and save your money for more critical items. It is a fairly easy job to replace it later when you can better afford it.
Larry in CO
09-16-2007 17:30:31
Mike,
Check with Steel Wheel Ranch for this also. Seems that I paid a lot less than that for a new one from Mike. Course that was about 4 years ago, but it seems that I only paid around $30 for it with a gasket. HTH. Larry
CNKS
09-16-2007 19:20:02
 Re: Question about a water jacket plate in reply to Larry in CO, 09-16-2007 17:30:31
Oddly enough Mike has an ad in the current issue of Red Power Magazine that lists them for $25. Could be a misprint.
Larry in CO
09-16-2007 19:34:19
 Re: Question about a water jacket plate in reply to CNKS, 09-16-2007 19:20:02
CNKS,
If I think about it I'll check my receipts tomorrow. I doubt if that's a mis-print. Mike is pretty reasonable on most of his stuff.
Larry
CNKS
09-16-2007 17:25:41
You can get by with the old one, but you have it apart, so replace it. As tractor parts go $55 is cheap, Case-IH probably wants twice that much. You also need a gasket. If I was "restoring" your tractor, I would have $4000 in it in a few months.
Bob Kerr
09-16-2007 19:38:54
 Re: Question about a water jacket plate in reply to CNKS, 09-16-2007 17:25:41
"If I was "restoring" your tractor, I would have $4000 in it in a few months." Yep! I still haven"t had the nerve to add up all the tranny and rear end bearings, electrical, tires and all the other stuff I fixed or replaced. It might be very close to that $4000 mark, but now the old girl is like new and working off the bills! It will probly be wore out again when it is paid off:(
georgeky
09-16-2007 20:14:11
 Re: Question about a water jacket plate in reply to Bob Kerr, 09-16-2007 19:38:54
Not hard at all to spend 4000 on any of them. Gonna cost me that much on an engine or two. Then it will need tires and one rim. I am looking at 6000 before all is done.
