F12 block
52G
09-19-2007 10:22:31
Does anything go on the back of the block where the cam bearing is. Took the bell housing off and the rear cam bearing is open to the outside. Should there be anything to go there other than the bell housing to stop oil from leaking by. Thanks for any help.
Dave Allgire
09-19-2007 15:58:27
 Re: F12 block in reply to 52G, 09-19-2007 10:22:31
Yep, there should be a gasket Part #24419-D. One place I know of to get one is Rice Equipment in Clarion, PA. 814-226-9200. Or you could apply a bead of Permatex Black Silicone and make your own gasket. Hope this helps.
52 G
09-20-2007 09:56:51
 Re: F12 block in reply to Dave Allgire, 09-19-2007 15:58:27
Thanks for the info.
