IH660D Oil seal part number??
srodster
09-22-2007 12:20:17
Help, can't find my parts manual for my IH660D and I want to know the correct part number for the oil seal that is on the left side while seated that has the clutch and torque amplifier hooked to it. There is a 1" solid shaft they both slide onto and its that seal I need that goes around that shaft. Mine is obviously leaking. Thanks for any help.
ejr-IA.
09-23-2007 10:56:51
 Re: IH660D Oil seal part number?? in reply to srodster, 09-22-2007 12:20:17
seal 380959r91 didnt see a bushing for clutch.
srodster
09-22-2007 12:39:51
Sorry, I misspoke. The clutch and left brake slide on the shaft that I need the oil seal. Also, do you know the part number for bushing that is inside the clutch arm that slides over the shaft? Hope I find my book. Anyone know where to look on the internet for parts diagrams?
Kevin Meier
09-22-2007 18:37:11
 Re: IH660D Oil seal part number?? in reply to srodster, 09-22-2007 12:39:51
have you tried www.cnh.com?
srodster
09-23-2007 04:34:57
 Re: IH660D Oil seal part number?? in reply to Kevin Meier, 09-22-2007 18:37:11
No, but I will. Thanks.
