F 12 crank
52G
10-05-2007 12:38:26
Anyone come up on two different size cranks for f 12 international engines. Can't find bearings for the one i have, B and C bearings are to thick. Could i put C rods in it, that would make the bearings work. Any ideas, thanks Ken.
moseed
10-06-2007 06:38:10
 Re: F 12 crank in reply to 52G, 10-05-2007 12:38:26
You'll be hard put finding nos original bearings. An option is to have your crank ground .002 and get the .002 over bearings from Rice. The problem there is the two shells (for each juornal) will be the exact same. They will not match at the notches when you install. You'll have to gring your own notch. Yes it is a pain.
steelfronts
10-05-2007 12:47:53
Ken I know there are different crank casting numbers and your machine shop should have the sizes on those casting nos. That will tell the tale but wont solve the problem. I have had the blocks line bored to fit the A B c bearings and I think the caps may have to have the lock moved to the other side. The machine shop easily did the work and it wasn't that expensive.
