Front steering shaft
Wardner
10-16-2007 14:32:09
I need a piece of 2" round bar. My parts 400 vertical steering shaft is the right size. Should I save this or use it on my fabrication project?
The meat of the question is whether I am likely to need it on another unrestored tractor. I have eight tractors that use this part.
Janicholson
10-16-2007 18:07:06
 Re: Front steering shaft in reply to Wardner, 10-16-2007 14:32:09
I'll add to the sage advice below that the shaft might turn out to be pretty darn hard to work with. It is not mild steel. If turning and drilling are needed it might be OK but welding to it might be tricky unless care were taken to use the correct process/rod. JimN
Wardner
10-16-2007 18:39:26
 Re: Front steering shaft in reply to Janicholson, 10-16-2007 18:07:06
Good thinking, Jim. Yes, it will be welded and I hadn't considered that aspect. I have subsequently found an old 2" SS pump shaft.
On second thought, the three levers that I intend to use on the shaft could also be broached at a local machine shop. I can do the keyways on the shaft.
If you are wondering what I am doing, I'll let you in. I am putting a 400 fast hitch on the front of a 400. It looks like it might work with both a wide and narrow front. Stay tuned for pictures, but not at 11pm.
Wardner
10-16-2007 18:34:18
CNKS
10-16-2007 17:35:58
That shaft was used on the M-450. That's nearly 450000 tractors -- shouldn't be hard to find. I broke one of those on an H one time -- luckily I wasn't in road gear.
Wardner
10-16-2007 17:45:20
 Re: Front steering shaft in reply to CNKS, 10-16-2007 17:35:58
I count it as a blessing that I don't have all those tractors. But then again, it might keep the Chinese steel mills going for a day or two.
glennster
10-16-2007 14:42:46
if it were me, i'd stop by a steel recycler and see if you can find a chunk of 2". i'd hate to cut up a good part, i imagine if still available that shaft would be mighty spendy.
